When turbo blew did engine run out of control until it run out of oil ??Mac1984 wrote:Hi all,
After several 1000mls across europe, i have arrived back home.
However, some events happened on the trip. The solenoid wire was the smallest issue.
Next thing was a blown turbo, that a garage replaced. Since then, the engine seems to be getting hot.
The gauge needle usually never moved above the N of the "Normal" print on the Gauge, now its always way above the
Middle of the gauge. Touching the radiator, the one side is ao hot, u can barely touch it, but on the other end, it is still cool, so the radiator is doing its job. Waterpump was done with the timingbelt earlier this year, thermostat is new and confirmed working, the radiator flushed and new coolant in the system.
So can it be something about the turbo itself? I am pretty sure the garage has just fired the turbo in without going to the bother of setting it up properly, then the communication there was not so easy either (far end of poland).
I also think acceleration wise its not as good as with the old turbo, but that again might be just the proper boost setting? Its quite smokey too, but only on the lower end, for example i am accelerating in a higher gear with lower revs, it would be smoking, but on higher revs and speeds it seems fine. They dont seem to have touched the fueling on the bosch pump, as the marking i have made on the max fuel screw is still there.
The temp gauge is not getting to the very top, but still it seems to be getting much hotter then usual. I dont recall the radiator ever being that hot before.
Maybe somebody has similar things happened?
I am always glad for any advice, i try to keep the old van on the road.
1998 2.5 Turbo with Bosch conversion. Everything else is factory.
Cheers
