The connect needs a bit of work, looks like I’m going to need to get the manifold off my Transit Connect TDCi engine. Need to give the manifold a proper clean as got the EGR problem, few questions.
- Does anybody know where there is a step by step guide?
- How long should I allow for the job?
- Only new part I can see I need is an inlet manifold gasket but have I missed anything?
- Are there any special tools I need? Heard I need to take exhaust manifold off, is there a chance I’ll need a torch on the bolts?
- Can I access everything from standing or do I need to get the car jacked up / on a ramp?
- Planning to use carb cleaner to clean the lot but is there a better option?
- Any other general tips?
- Need to change cambelt and oil change soon, is it worth doing all together?
Thanks,
