Mk6 Transit recovery indicators not working
Postby Flusted » Mon Oct 15, 2018 8:41 pm
HELP! I've been tasked with the job of fixing my friends indicators on his mk6 transit 2.4D recovery truck
I've done plenty of googling but haven't got anywhere yet so am hoping the wealth of knowledge can be found on this forum.
So far, I know the hazard lights are working and I believe it only has the 1 5 pin relay above pedals which has also been changed.
I've removed the engine fusebox and looked for dodgy connections but no luck
Can anyone give me a list of things to check please?
I'm a marine electrician by trade and obviously have a multimeter
Thanks in adbance
Flusted
Re: Mk6 Transit recovery indicators not working
Postby Altransit » Mon Oct 15, 2018 11:18 pm
I would start by looking for switched power at the indicator switch itself. I think you'll find the fuses are in the fuse box behind the glove box, but you'll find fuse info here:-
:arrow: viewtopic.php?f=40&t=71739
Postby bambi mk 1 » Mon Oct 15, 2018 11:33 pm
Altransit wrote:I would start by looking for switched power at the indicator switch itself. I think you'll find the fuses are in the fuse box behind the glove box, but you'll find fuse info here:-
x 2 and double check the flasher unit :idea: It controls both the indicators and hazards and each one can go down seperately :wink:
bambi mk 1
Postby Flusted » Wed Oct 17, 2018 7:21 am
I've checked all the fuses and the indicator stalk has been changed for a working second hand 1.
I read something about checking theres 12v on a pink? Wire to stalk switch?
Flusted
Postby APH » Wed Oct 17, 2018 11:58 pm
What age truck is this? there are two systems used for the indicators, and they are both quite different in there operation.
Andy :D
(\__/)
(")_(")
this is bunny
APH
