replacement pump
replacement pump
Postby B4ndit » Fri Oct 19, 2018 8:04 pm
Hi,
can anyone tell me what parts i need to convert from lucas epic pump to bosch mechanical pump many thanks
ps i have a bosch pump just need to know what other parts i need and if it's worth doing the job
B4ndit
Re: replacement pump
Postby joinerman » Sat Oct 20, 2018 6:35 pm
Throttle pedal & cable, new cam belt & water pump, live wire from ignition ( fused ) to the start stop solenoid.
joinerman
Postby B4ndit » Sat Oct 20, 2018 10:25 pm
Many thanks for the reply
B4ndit
Postby wojciech » Thu Oct 25, 2018 8:11 am
B4ndit wrote:Hi,
Find more information about Bosch pomp - from what period it is. In Mk3 pomp had 25,4 mm narrow wheel with 2,5 mm low teeth, in Mk4 and Mk5 to 1997 it was 25,4 mm narrow wheel with 3,5 mm high teeth, in Mk5 from 1997 27,6 mm large wheel with high teeth.
Theoretically each pomp can work in each engine - provided that you give correct cam belt. Belt with high teeth can not works on wheel with low wheel, large belt can not works on narrow wheel.
wojciech
