Hi folks
After recently changing the gearbox and driver side front strut i now have no horn and the airbag light is on with fault code 32
Fuse hasnt blown and i cant see any loose wires
Any sugestions?
If that doesn't work probably faulty squib/clock springPunto443 wrote:Trapped any wiring in between the engine/box?
But more likely that a plug has been knocked out under the steering wheel while working on the top strut mount
