Cider Andy wrote:ETIS build data for my 2006 and 2007 vans states they have "Power 4-Wheel Disc Vacuum Boost", but my 2011 van has no mention of it.
Obviously they all have a brake servo, which is the only thing I can imagine it means, but that wouldn't involve any wiring.
But he's got the specail booster cables Sir knobby, bet you've got yer booster cables fitted so you've got maximum boost available upon pressing of pedal sirknobby1 wrote:Cider Andy wrote:ETIS build data for my 2006 and 2007 vans states they have "Power 4-Wheel Disc Vacuum Boost", but my 2011 van has no mention of it.
You're overthinking things....just replace the disks, pads and reconnect the pad wear looms and be done with it.
Enlighten me please regarding wheel and bolt technique for disc removalMarauder wrote:Ok Guys today I started to remove old Disc and pads also have managed to get that big Nut undone (What a Game) So wheel off, Torx bolts removed, Big hub Nut now off,, Any ideas HOW to get the assembly off I thought that the hub/and Disc/Rotor would just pull off so I could then set about getting the old Disc off (using the wheel and bolt method ) I started to undo the 4 bolts on the rear but stopped and thought IS it Necessary to undo the 4 bolts on the rear to remove the hub ????
Marauder wrote:As per what you said. EXCEPT Hub wont pull off that stub axle.??????? I don't why not. Going to try a Hub puller later on !
Marauder wrote:Ok Guys, The Latest. I now have the Hub off,I checked and re-checked I had removed anything Holding the Hub. I put my thinking cap on and got my old trusty Hub Puller I had laying under my Bench. Fitted it to the Hub and after a few Tons of pressure the Hub started to move,It fort me all the way until the Hub came off, The reason I think who ever changed the last set of Discs and Pads never put any type of grease on the stub axle as when I removed the Hub from the Stub Axle everything was rusty and dry not allowing any movement. So there you have it,now I have to go all over it again on the offside next.... I have cleaned up the Stub Axle and ordered a new Hub with Bearings,,( Things like this only happen to me lol)
