I've been looking around for a replacement QVFA engine for my LWB high roof FWD T300 mk7 that doesn't cost twice as much as the van's worth, but without success. I do have a good P8FA engine but I didn't think Ford had ever put the 85bhp engine in a van this size. It turns out I'm wrong; they did!
So the current plan is to fit the P8FA and mess around with the QVFA on the bench* with a view to refitting it if all it needs is a timing chain. Which brings me on to the PCM. I'll be setting the existing PCM aside so it can be simply refitted if I go back to the original engine. Meanwhile I'll be fitting the PCM that's mapped for the 85bhp engine. Will I need to do anything with the replacement PCM in terms of programming it?
*by "bench" I mean this. In the winter. Yippee. You guys with workshops don't know you're born.....
