Brake Fluid Spec Question
Postby MinOMins » Fri Nov 16, 2018 4:20 pm
Hello,
Looking for thoughts/advice...
I changed the brake fluid on my 2010 Mk7 Van a couple of years ago.
Yesterday I done a service and realised the brake fluid needs topped up. It seems the spec has changed...
Is it possible to mix the two specs?
Old spec: SUPER DOT 4, WSS-M6C57-A2
New Spec: DOT 4, LV High Performance, WSS-M6C65-A2
Mk2, 1980 W, 2.0 Pinto, Twin Webers, SWB, SHR, swapped 94k
Mk3, 1999 T, 2.5 Di, LWB, SHR, Sold 72k to pestering mate
Mk3, 2000 V, 2.5 Di, SWB, SHR, Welded for ever and Scrapped 385k
Mk7, 2010 60, 2.2 SRFA Engine, 115/T280, FWD, DCIV, SWB, MHR
MinOMins
Re: Brake Fluid Spec Question
Postby dumper » Fri Nov 16, 2018 10:36 pm
Brake fluid level should never need topping up you may have a leak or since you change the brakes fluid your brake pads have worn down so fluid level will drop in the brake reservoir so if you top it up now when you fit new pads it will blow fluid out of the reservoir but saying that don’t let it get lower then the clutch feed from the reservoir look for leakage on both systems and pad wear sorry I have no idea about fluid spec
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby Cider Andy » Sat Nov 17, 2018 11:03 am
MinOMins wrote:...Is it possible to mix the two specs?
New Spec: DOT 4, LV High Performance, WSS-M6C65-A2...
Yes, they are chemically compatible and can be mixed.
Drink moderately, eat healthily, exercise regularly, die anyway.
Cider Andy
