Nicely put Jim ArcherJim Archer wrote:The pressured sealed expansion tank saves having 2 points to top off the cooling system, plus acts as a high point that ensures that all the time there is coolant present in the tank, it is above the level of the engine cooling galleries/pump. And they act as a de-aerating vessel, after a 3mins, the coolant becomes a air/fluid emulsion due to the micro-bubbles that develop during rapid heat transfer being scrubbed away from their initiation points by coolant flow over the surfaces, a combination of high system pressure, plus easy venting to the tank keeps this to a minimum.
It also solves the problem of a shagged pressure cap vacuum valve that allows fluid out, but pulls air in.
Then we have the useful trait of air being compressable, where fluid isn't.
Jim
Altransit wrote:WThere was always a fill level in the radiator about 3/4 inch below the filler cap
rebuilder86 wrote:Altransit wrote:WThere was always a fill level in the radiator about 3/4 inch below the filler cap
I want to see one of these fil level thing suggesting to fil below the brim. any idea where i can see pic of one on the net?
Jim Archer wrote:The only robust thing on a DI engined van is the engine. It'll still be going strong long after the rest of it is being made into new stuff in China.
Jim
