HI All,
Well been searching the net for the specs for a T 450 van with out much luck.
Was wanting to know if some one might be able to tell me if the rear drum and front disc is the same size as a T 350?
Believe the T 450 is weight rated for 450 KGS as is the T 350 Rated for 350 KGS, so interested in the brakes are the same or larger?
thanks in advance for advice.
