You could've kept tank where it was and just turbo'd it with the left exhaust pipe round the back of the engine over g/box to conect to fabricated turbo manifold , then one big pipe to down the righthand side to the rear.......Ecotec wrote:Hi I have two ford transits the older model a 2002 we had to give a different power plant that is a commodore V6 Ecotec and four speed automatic gearbox, we had to customise aluminium fuel tank as we had to make room for the extra engine pipe on the left hand side (passenger) being a v configuration, using the original sender I have it all back together ready connect fuel lines to the engine, what I need to know is which colour fuel fitting is the return line and which colour is the pumped line I have a white connection at the top of sender as well as a red one, can someone help me out? Thanks
Do both pipes fit both sender unit fitments ???..... They're usually different so you can't mix them upEcotec wrote:There is no fuel in the new tank yet to try that one and I can't fit tank till I fit the plug in return and pump, plus everything is still disconnected and battery disconnected.
