Mad Husky wrote:Duff relay ?
Altransit wrote:Engine running?
Have you tested for power at the screen terminals, and at the relay terminals? Checked the earths?
Altransit wrote:Was the screen an original fitment, or put in later
If the latter, you need to "tell" the BCM that the van has a heated screen
Altransit wrote:I believe that there are fuse for the HFS under the drivers seat, but I'm not 100% sure
Punto443 wrote:Those feeds under the seat are the high current ones to the relays, sounds like the prob is just on the low current switch side.
Punto443 wrote:From memory the screen controlled by the bcm and it’s negative switched through it.
This may be a configuration issue instead of a wiring one?
Users browsing this forum: metalworker0
