P2463 soot accumulation can’t clear code. Ids???
Postby ballihoo » Sun Feb 10, 2019 10:06 am
Morning,
So I’ve had this code for a while now. I’ve just changed the pressure sensor and the vaporiser on my 2014 mk7 rwd transit 2.2 euro 5 125tipper. When I first tried clearing the code it came back straight away. Did a small 20 min drive home on back roads and clears the code 5 mins away from home. It stayed gone for the last 5 mins. Switched engine off and it stayed cleared. Came back to it 5 mins later and it was back.
Tried taking it down the motorway and couldn’t get the egt more than 370c.
Do I need to get ids and force a clean or I read about resetting the dpf values??
It is using slightly more diesel currently.
I really don’t want to have to take it to the dealer..
Pipes to sensor seemed okay and wiring looks okay as far as I can tell.
What’s next? Any help greatly appreciated!!
Mk7 2.2 t350 tipper 2014
ballihoo
Re: P2463 soot accumulation can’t clear code. Ids???
Postby ake » Sun Feb 10, 2019 11:44 am
It most probably needs a new vapouriser, fuse for vapouriser replaced and then a static regen
Take it to someone who knows Transits and it’ll be fixed for £200. Take it to someone who doesn’t, and it’ll cost you £1000 and do the same thing in 6 weeks, because they will replace the dpf but not fix the problem
If it was me, I’d put it to a Ford Dealer unless who know someone locally that knows what they are doing
Postby KING OF ENGLAND » Sun Feb 10, 2019 8:57 pm
You have received some excellent advice there
£200 or £1000 plus easy decision I think
KING OF ENGLAND
