Fuel line issue
Fuel line issue
Postby tjmarine » Sun Feb 10, 2019 6:12 pm
Hi all and apologies if this has been covered
I’ve had to bleed my fuel line by removing the right (as you look backwards) aft hose from the filter assembly and fitting a pruning pump.
How in the world do you refit the pipe. I’ve tried warming it with a heat gun burnt won’t gonove the ridges on the filter fitting.
Please help I need my van tomorrow.
Mk7
Tim
tjmarine
Re: Fuel line issue
Postby knobby1 » Mon Feb 11, 2019 12:19 am
You shouldn't need to bleed a Mk7, they're self bleeding. Normally we just fill the new filter with fuel before fitting and you should be good to go.
The hose fittings are just push-on jobbies, maybe the O-ring inside the fitting has dislodged or summink...??
Re: Fuel line issue
Postby andz327 » Mon Feb 11, 2019 2:26 am
knobby1 wrote:You shouldn't need to bleed a Mk7, they're self bleeding. Normally we just fill the new filter with fuel before fitting and you should be good to go.
It's the PRUNES that's causing problem
ANDZ
andz327
Re: Fuel line issue
Postby knobby1 » Mon Feb 11, 2019 5:23 am
andz327 wrote:It's the PRUNES that's causing problem ANDZ
LOL... :lol: :lol:
I'd like to see this "pruning pump too" would indeed be interesting.
Re: Fuel line issue
Postby Jim Archer » Mon Feb 11, 2019 11:30 am
Wonder if the OP has pulled the line off the connector itself rather than the connector off the filter head stub?
Jim
Mk7 140 Jumbo - Vantunered.
289,000 and counting.
Jim Archer
Re: Fuel line issue
Postby andz327 » Mon Feb 11, 2019 12:49 pm
Jim Archer wrote:Wonder if the OP has pulled the line off the connector itself rather than the connector off the filter head stub?
Jim
Was thinking that maself mate, instead of pressing the buttons in he's split pipe from connector........ Can see a new main fuel pipe getting bought soon
ANDZ
andz327
Re: Fuel line issue
Postby Airthies » Mon Feb 11, 2019 9:57 pm
If it's off the fitting then it might be a bit short now if it's been cut, otherwise a cup of boiling water will soften it though it might fail to seal properly now.
Go get an elbow complete with a 6" length of pipe cut off a scrapper then get a straight connector from a motor factors agricultural dealer (If there's any around) or Halfords and cut your old pipe to join in the new bit
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Re: Fuel line issue
Postby andz327 » Wed Feb 13, 2019 12:09 am
What was original problem that made you fook aboot with fuel pipe in first place mate
ANDZ
andz327
Re: Fuel line issue
Postby knobby1 » Wed Feb 13, 2019 1:52 am
andz327 wrote:What was original problem that made you fook aboot with fuel pipe in first place mate
ANDZ
I'm guessing he's fitted a new "empty" fuel filter and tried to start it....usually doesn't end well.
