dumper wrote:Did you use genuine or pattern part mine whent at 100.000 k fitted gen ford was still ok at 150.000 when I sold it every time I use pattern parts it seems to bite me in the backside I now only use gen ford parts fit once and forget
jonb1 wrote:does it squeal when just idling or just when under load? if at idle it is usually the top guide & or tensioner bearing, i fitted a lot of these 8 to 10 years ago i never bought cheap parts but some would last 50k others would fail after 2/3k, if you take belt off & spine guide & tensioner pulleys by hand you can hear if the bearing is rough also grab hold of pulley you often could feel play as well, if they get real loud they are normally close to collapse & will throw aux belt off, while you have aux belt off you can spin water pump alternator etc to check for noise /play
hope that helps
Mad Husky wrote:I had the same problem couple of weeks ago it showed me what was wrong when the belt shreaded and the tensioner collapsed, I believe the main culprit was the alternator had started to seize causing undue stress on the tensioner worth checking all other items connected i didn't enjoy the repair bill and i did the work.
firewalker wrote:Mad Husky wrote:I had the same problem couple of weeks ago it showed me what was wrong when the belt shreaded and the tensioner collapsed, I believe the main culprit was the alternator had started to seize causing undue stress on the tensioner worth checking all other items connected i didn't enjoy the repair bill and i did the work.
How long was it going on for prior to that?
Mad Husky wrote:firewalker wrote:Mad Husky wrote:I had the same problem couple of weeks ago it showed me what was wrong when the belt shreaded and the tensioner collapsed, I believe the main culprit was the alternator had started to seize causing undue stress on the tensioner worth checking all other items connected i didn't enjoy the repair bill and i did the work.
Off and on for about 7 months but not constant sometimes it was quiet other times it was bad and embarassing when going through town, I couldn't see anything wrong with the belt or tensioners untill the tensioner collapsed taking the belt only when it was off could i see the real culprit my slternator which by the way was still working and charging the battery. Spinning it by hand it wouldn't turn so put the squeal down to it sticking and dragging the belt across the pulley.
Mad Husky wrote:Yes should spin freely along with the other pulleys as well my waterpump span freely so did the vac pump can't remember if power steering did or not must have been ok as i wasn't worried about it. on a side note the idler pulley felt rough so that was changed along with the tensioner I used quality parts not original i don't think europarts what ever they supply.
firewalker wrote:Noticed oil around a pulley casing - could be onto something!
Starts up, after a short while oil fine sprays onto belt and causes squeaking???
It's the bottom right pulley looking at it from the front - can anyone tell me what it does?
