90bhp 2.4 tddi white diesel smoke
Postby Stuart1989 » Thu Apr 11, 2019 12:31 pm
I had a post 6 months ago but cannot find it. Transit 2.4 mk6 tddi 90bhp stinks of diesel and white smoke startup. When pulling away will smoke a bit with slight hesitation low down revs then gets past hesitation and clears no smoke. Once drove it clears up so only start up and pulling away from being sat. If left a hour will do same. If you start and give good hard Reg witll clear but when pulling away bit of smoke then the get pas the slight hesitation it clears. Once cleared no more smoke untill switched off. I have checked timing spots on. No faults when plugged in. Tried genuine filter and a Mann fuel filter still same. It’s 143k would cracked filter housing do that or injectors.
https://youtu.be/XlPpDy3pnUQ
Stuart1989
Re: 90bhp 2.4 tddi white diesel smoke
Postby Daveyandbev » Thu Apr 11, 2019 1:13 pm
I would think its down to leaking injectors. Can you get them tested at a fuel injector specialist?
Ford Custom Tourneo 2013 2.2
Daveyandbev
Postby Stuart1989 » Thu Apr 11, 2019 1:15 pm
I have a complete set of injectors and another pump but limited time. Any advice on getting old injectors our and can’t pry on rocker cover as will crack
Stuart1989
Postby Mad Husky » Thu Apr 11, 2019 3:09 pm
I bought the socket to remove them cost me about 14 quid still not done the job though how's the turbo and intercooler if fitted I know the engine breather goes to the inlet turbo hose how much oil coming down that.
Mad Husky
Postby Stuart1989 » Thu Apr 11, 2019 4:17 pm
Turbo looks clean and breather. I got a socket just don’t know about pulling them out
Stuart1989
Postby Mad Husky » Thu Apr 11, 2019 4:21 pm
Stuart1989 wrote:Turbo looks clean and breather. I got a socket just don’t know about pulling them out
You and me both no idea till itry lol i know undo fuel line clamps and remove fuel line out the way remove upper seal then that's as much as i know.
Mad Husky
Postby Daveyandbev » Thu Apr 11, 2019 7:42 pm
Daveyandbev
