Hi,
I’m having a bit of a time with ride heights, this weekend. Hope you guys can help out.
When I bought my Mk7 Sport, it was fitted with heavy duty rear springs, as it was used for towing.
The clearance in the arches was huge, and looked terrible.
I have now fitted lowered springs from MRS, but now I think it’s just TOO low.
Question is: can you buy spacers to go between the spring and axle, to raise it slightly (about 35 mm)??
I thought about using Escort/Capri aluminium lowering blocks. The springs sit below the axle on the cars, so the blocks drop the ride height. On the van, it’s the opposite.
Would this work, as the set up is basically the same??
OR
As I said above, can you buy proper parts to do this??
THANKS FOR READING
