P1174 engine code after swap
Postby colinhamilton » Sun Jul 21, 2019 11:30 am
Hi, recently changed transit 2011 engine 2.2rwd engine over. Started up 1st turn of the key but have an engine light on and p1174 cam sensor fault. Checked both cam and crank sensors all the earths and all the other connections seem to be in good working order. Hit a rock and wondering if I’ve missed anywhere? This is the second engine that has been fitted to it. 1st one snapped a camshaft and was driving fine before hand. Thanks in advance.
colinhamilton
Re: P1174 engine code after swap
Postby andz327 » Fri Jul 26, 2019 4:51 pm
Do you get 2011 2.2 rwd ??
Cams snap when timing chains jump or break unless oil pump has given up and cams seizing due to lack of oil
ANDZ
andz327
Postby andyc24 » Thu Oct 10, 2019 4:35 pm
Hi, I have the exact same fault. New engine fitted now P1174 cam sensor fault coming up as soon as it is started. Rechecked cam timing. Timing is spot on. Runs ok just coming up with this fault? Did you manage to sort yours? Cheers, Andy.
andyc24
Postby randrcars » Tue Nov 17, 2020 2:09 pm
Hi, did you guys manage to sort out the problem, I've just changed the engine and getting the same fault.
randrcars
Postby Dave jenkins » Mon Dec 07, 2020 3:34 pm
Any news on a fix for this. Just had my engine rebuilt. Now fitted and have this fault code. Starts perfectly but slightly lumpy at idle. Disconnect the cam sensor and it barely starts.
Cheers Dave.
Dave jenkins
Postby Dave jenkins » Tue Dec 08, 2020 7:59 am
If interested, I’ve cured it. I needed to reset the learned values for the pcm. I can only assume the old engine had a stretched chain which the pcm had picked up over the years and the new one with a new chain threw it out. Having reset the values and starting it up it was lumpy and hunting for a minute while it relearned the values but the code didn’t reappear and after a good road test throughout the speed range up to 60 the engine is running as it should with no codes coming up.
Dave jenkins
Postby Jmc » Tue Jul 04, 2023 4:40 pm
I can confirm this fault and fix
Engine swap I did also had a stretched timing chain
And cam sensor fault after fitting new engine
Reset the values so far so good
Jmc
Postby knobby1 » Wed Jul 05, 2023 11:16 pm
Jmc wrote:I can confirm this fault and fix
Thread is 4 years old and some of the guys you're replying to haven't been back on here for years.
Postby Altransit » Thu Jul 06, 2023 10:58 am
knobby1 wrote:Thread is 4 years old and some of the guys you're replying to haven't been back on here for years.
True, but at least the next one asking will have the answer as well 8) :mrgreen:
Postby Nat3063 » Wed Dec 18, 2024 6:18 pm
Hi just had my timing chain replaced and now have these codes p1174 and p0341 new cam sensor has been fitted van runs but won't go over 2000 rpm how did you manage to reset the learned values. Any help really appreciated
Nat3063
Postby knobby1 » Mon Dec 23, 2024 9:28 pm
Nat3063 wrote:Hi just had my timing chain replaced and now have these codes p1174 and p0341 new cam sensor has been fitted van runs but won't go over 2000 rpm how did you manage to reset the learned values. Any help really appreciated
Euro-4 or Euro-5..??
Either way, the engine will not start unless you have cam/crank sync.
Could just be a poorly/intermittent connection.
