by Frag » Sat Oct 19, 2019 1:12 pm
If you don't have any codes or warning messages relating to soot load,why do you think it needs a regen or that the dpf is causing a problem ?
70% full is acceptable normal level without causing any issues or concern,it won't try to regen till near the 100% mark.
If it wasn't doing regens it would be above this and you'd have dtcs,if it goes above 150% due to a fault,then the eml will come on,and it will not do a dynamic regen,will have to be static.
If it still climbs higher,it will go into reduced power (3k rpm max) and you have to do a stabilisation routine before static regen.
Above 320% blocked its game over,cannot be regenned,needs a new dpf.
