Airthies wrote:Yesi do, I've had it for two years it's more noticeable in the winter, done several flushes of fluid and only marginally better, pump change made no difference so going to change the rack, but I can't be arsed removing it so the one I'm replacing it with comes with a complete van
Indeed a bit extreme but hey ho I'm not known for my mediocre effortsRustWidow wrote:Airthies wrote:Yesi do, I've had it for two years it's more noticeable in the winter, done several flushes of fluid and only marginally better, pump change made no difference so going to change the rack, but I can't be arsed removing it so the one I'm replacing it with comes with a complete van
Well, that’s a bit extreme lol. My steering sticks first thing when I move off, sorts itself out fairly quickly but this morning it felt like I was trying to turn a bloody juggernaut
andz327 wrote:Me tae , i was thinking i had a dry ball joint?
ANDZ
Wouldn't be the first time either sirknobby1 wrote:andz327 wrote:Me tae , i was thinking i had a dry ball joint?
ANDZ
That'd be painful....you wouldn't know where to lay it for comfort..
I've got one of those lists mate and it keeps getting biggerloot wrote:Mines a bit stiff so I need to move it slowly I've added it to the list of things to do
andz327 wrote:I've got one of those lists mate and it keeps getting biggerloot wrote:Mines a bit stiff so I need to move it slowly I've added it to the list of things to do
Sent from my SM-G975F using Tapatalk
Looty your moving it too slowloot wrote:andz327 wrote:I've got one of those lists mate and it keeps getting biggerloot wrote:Mines a bit stiff so I need to move it slowly I've added it to the list of things to do
Is when it stops being stiff we need to be concerned
andz327 wrote:Try changing fluid again but change more this time , empty the reservoir and fill, start enginge long enough for new fluid to pump into system then drain and refill and repeat until its all new fluid. Comma power steering fluid and conditioner worked well with mine a while back, also like Nedo said could be a fooked ball joint or two, could be worn tyres , may need belt change or crank pulley on way out , does it sound like a budgie stuck under bonnet at tickover???????
ANDZ
