bambi mk 1 wrote:hetman wrote:bambi mk 1 wrote:Before doing anything fit an extra pair of battery leads parallel to the ones already fitted
What?!?!
Please elaborate. Is this advice only for when I'm trying to test the cold start device as Keef explained? Or something missing on my van at the moment? And how would I go about getting or attaching these leads?
Keef,thanks for the extra info. I"ve attached a few more pics; perhaps you can get a better view now?
Also, someone in the Econoline group I have on Facebook suggested that these engines need sometimes 10 turns of the starter before they cold-start. I did try that this morning at 35F and after about 10 turns, it did fire up! So I am actually quite excited that the van might be "OK" as is. Especially in light of the information that these Di engines don't have ANY system to preheat the fuel (except for that optional system).
Bolt 2 extra leads from the battery ,one to the live on the starter and one to an earth on the engine.The cold start and excess fuel is not working on it either.The brass switch with the red centre and two terminals is not connected,you need an ign switched live to it and a wire from it to the rheostat on the pump.The cable inside the rubber boot on the pump may be broken as the lever should be fully back when the engine is cold.Try pushing the lever back with a handle of a hammer when someone else turns the key
Great, informative post. Thank you. Now I'm lost, and need some further explanation. How large/thick should these leads be? So, you are talking about things which are missing on my van, correct? One lead from the negative battery post goes to the engine, as a ground (earth), and another lead from the positive battery post to the starter?
"The cold start and excess fuel is not working..." On my van? Which cold start are you talking about? The optional flame plug which it seems is installed in my van? You can tell it's not working by the missing wiring? And about the excess fuel...what is that? I understand that attached to each injector is a fuel hose return line. The cylinder closest to the front of the van has a fuel return line coming to it but another rubber hose seems to be blocked off. I was curious about that. Should it be open and leading to some other place? If so, to where should I lead it? This means that no excess fuel can escape; that sounds not good.... and could be causing what problems or symptoms if it is not working?
The brass switch (thank you!) with the red center is not connected. There should be a wire from the ignition attached to one terminal and another wire from the fuel pump (the Bosch mechanical fuel pump?) to the other terminal....OK. I will look to see if there are the remains of these wires somewhere that I can splice into. Why would someone delete this (and the other things)?? Which lever are you referring to? Can you see this in the pictures? Is this lever part of the Bosch mechanical fuel pump on top of the engine, or are you talking about the small fuel pump at the back of the engine which draws fuel from the tank? I will post a picture of that. Can you show me where the rheostat is and the rubber boot you mention? Perhaps a picture of a healthy engine so I can compare?
This is the exact sort of information I need and have been missing. Thank you so much.
EDIT: I just went outside to look at the engine again. Based on your explanation, I can now make out that the thick blue cable is indeed running to and connected to a flame plug system, which is not factory, as mentioned. Someone has added an aftermarket flame plug, and yes, the fuel is being drawn from the top of the Bosch pump! The other end of the thick blue wire goes to a cheap-looking relay hanging above the battery, and then leads to the positive battery post, and there is also another small wire going back to behind the firewall, which I'm sure must lead to that glow plug actuating button on the dash. Also, I checked the injectors and return line again, and there is a hose running from the rear-most cylinder down to the fuel filter lines (return line). So that should be working correctly, or not?
