Hi all,
I had an overheating issue where the van seemed to overheat and the guage went to the red and then the engine cut out.
I called Rac out and got the readouts:
DURATORQ-DI - 2.0L - 74 (101)
DTC: P1576,Pedal Position Not Available
DTC: P1342,Pedal Demand Sensor A Circuit Range/Performance
DTC: P1343,Pedal Demand Sensor B Circuit Range/Performance
DTC: P007F,Charge air cooler temperature sensor bank 1/2 correlation
I have since replaced:
thermostat
cylinder head sensor
cleaned intercooler
and replaced accelerator pedal
filled with new coolant (red OAT)
the issue still continues.
I am ordering a head gasket test kit and in anticipation a new water pump, gasket and grease (is copper grease correct for between water pump and Power steering pump?)
i have seen similar posts on here and found some useful information but wanted to ask for any more advice on changing the water pump. I have already had the PAS belt off and am a little worried about taking the EGR metal pipe off to get to both pumps as the bolts look pretty rusty. I am not a mechanic but have time on my side at the moment.
any advice much appreciated.hoping its not the head gasket!
