JustJames wrote:you would have no compression
short stoke in a long stroke block means the piston will not get to the top of the chamber
deck the block or fit taller pistons but then you have either lost integrity in the deck
or
you have made a heavy piston that will cause you more issues than you gain from a short stroke
JustJames wrote:as the opener was to use an existing crank from another ford product
yes, longer rods is the way to do it, but that would mean getting custom rods made from the ground up and that's not cheap at around £2k for some by Arrow
taller pistons can be easily achieved by finding a near match at nearer £400
correct diameter or a plus size and machine the bores
correct size on gudeon pin
and machine to suit the height
its all hypothetical as I doubt the crank would fit, haven't looked but are the journals different?
