Tpaynter wrote:I have a problem my pats control unit is dead... Have found some with the same long number in yellow. But can't find any with the shorter number underneath.
What does the numbers mean
Does it matter about the short number?
Can anyone point me in the right direction?
Legends
Tom
Sent from my LYA-L29 using Tapatalk
Also struggling to find a ECU port in the van, as there are loads of old electronic plug ins scattered around the van, as it used to be used as a disabled bus back in the day.knobby1 wrote:Tpaynter wrote:I have a problem my pats control unit is dead... Have found some with the same long number in yellow. But can't find any with the shorter number underneath.
Legends
Tom
Would help if you told us what vehicle it was for..??
Thanks for that I'll have a look!Jim Archer wrote:My next question was to be is it a EPIC TD? You will need either, Lucas Laser, Ford FDS, or a official early version of Ford IDS and the appropriate connector plug.
The port itself is in the fuse box, behind the spare fuse carrier.
Is it making the noise permenantly, or only at certain times or operations?
Jim
Tpaynter wrote:The code with the yellow background is the same as my truck but the orange circled number isn't the same , would it work as a replacement?
Do you know what the number mean orange circle?
Thanks chuggy, is the pat number the short number or the long one on the unit?Chuggy wrote:Search the part number, Transit, Escort, Fiesta all use that same unit so as the numbers match I think you should be ok.
Tpaynter wrote:Thanks chuggy, is the pat number the short number or the long one on the unit?Chuggy wrote:Search the part number, Transit, Escort, Fiesta all use that same unit so as the numbers match I think you should be ok.
Great info on this cheers guys, love this forum!!MinorMatt wrote:I will send you a message
Tpaynter wrote:Also struggling to find a ECU port in the van, as there are loads of old electronic plug ins scattered around the van, as it used to be used as a disabled bus back in the day.knobby1 wrote:Tpaynter wrote:I have a problem my pats control unit is dead... Have found some with the same long number in yellow. But can't find any with the shorter number underneath.
Legends
Tom
I don't even know what I'm looking for, I read that sometimes there under the bonnet.
Thanks for helping me out and replying!
Users browsing this forum: seanl82
