Dave Deeda wrote:Hi, long time ago, don't know if you'll get this, but did you solve the problem ? My glow plug light has started flashing..
Dave
Dave Deeda wrote:Hi, thanks for replying.
I was drawn to this particular thread by similarities with my problem.
Currently no codes...I had a mobile car electrician come out initially to sort out a no headlight problem...I was a bit concerned that he had trouble identifying which relay was which, but in the end he made a wire between a relay and the battery which seemed to solve the problem.
Up to this point he had been turning the ignition on without starting the van to check the lights.
After he went, I started the van once, then second time the glow plugs started flashing and won't start.
Never happened before and I obviously think issue is connected.
Electrician can't see me again until Monday...trying to tell me it's nothing to do with what he did.
I suspect that by constantly turning on ignition to check lights, and leaving ignition on ( thus activating glows plugs ) something has burnt out.
Either that or his wiring is shorting something out. In the new wire he put in it was only meant to be live when ignition on, but it appears live all the time, and when I turn key to try to start, it blows the fuse in the line that he put in..
Dave
