Paulscarbs wrote:Question for those more knowledgeable than I.
Is the cylinder balance something to be concerned about?
If so, do I need to enable a relearn?
Paulscarbs wrote:How do I run an injector leak test? You mention it seems ok.
You pointed out the MAF reading seems strange.
What should healthy readings be for all of these?
TIA
Paulscarbs wrote:I'm awaiting parts to complete the leak off test but thought I'd video the engine running for anybody else to try and ascertain whether there are unwanted noises coming from the engine.
By and large I think it runs well.
Towards the end of the video there is evidence of a distinct 'pinking' style noise. This is evident if stood in front of the vehicle but not really on the video (until the end section).
Might this be the over fuelled cylinder?
https://youtu.be/_hTJUgYa3QU
Paulscarbs wrote:Thank you for listening.
I guess you don’t hear anything untoward otherwise you would have indicated.
Paulscarbs wrote:Yes, and that's what I need to learn - to do the Learns!
Paulscarbs wrote:Great. The learns were done this time last year so it's timely.
Still leaves me with the problem of needing to learn how to do them though.
Paulscarbs wrote:I have, that's how I know one of the cylinders is overfilling (above).
Just don't know how to go about the procedure.
Users browsing this forum: metalworker0
