Mk7 transit oil pump
Postby Simon13 » Fri May 01, 2020 1:55 pm
Anybody had any experience with cheep oil pumps off ebay running oil presure to high and bursting oil cooler :?
Simon13
Re: Mk7 transit oil pump
Postby blue estate » Fri May 01, 2020 2:05 pm
Simon13 wrote:Anybody had any experience with cheep oil pumps off ebay running oil presure to high and bursting oil cooler :?
What van ? engine size hp age ??
blue estate
Postby Simon13 » Fri May 01, 2020 2:26 pm
2012 transit mk7 swb fwd 2.2 tdci 85hp
Simon13
Postby blue estate » Fri May 01, 2020 2:30 pm
Was the oil cooler the original ? and how many miles the van done
blue estate
Postby Simon13 » Fri May 01, 2020 2:52 pm
Bought van as non runner chain had snapped it's done 145000 miles
Built it back up cleaned it all out new pump and chain etc not long after oil cooler stated leaking so replaced with new one and the same has happened again not tested oil presure yet but I'm assuming it's to high and trying to force oil out at the weakest points.
Simon13
Postby blue estate » Fri May 01, 2020 2:55 pm
Are you sure it's the cooler gone and not residual oil in coolant that wasn't cleaned out ? (just trying to get all the facts )
also where did pump and new cooler come from ?
blue estate
Postby Simon13 » Fri May 01, 2020 3:16 pm
Both pump and oil oil from ebay. Decently coming from oil cooler made a right mess of engine bay blew seals out were the cooler is bolted on to the oil filter housing.
Simon13
Postby bambi mk 1 » Fri May 01, 2020 6:26 pm
bambi mk 1
Postby nelly001 » Mon Jan 30, 2023 6:30 pm
Did you get to the bottom of the problem as I have exactly the same problem
nelly001
Postby knobby1 » Mon Jan 30, 2023 9:03 pm
nelly001 wrote:Did you get to the bottom of the problem as I have exactly the same problem
Unfortunately he hasn't been back here since May 4th 2020, so we may never know.
