hi, mk6 side loading door mechanism
The central locking is not energising the lock mechanism, ive read alot on here. Cleaned the three pins checked the continuity through the short harness, aligned the pins to the striker,cleaned the striker, pushed the door in while pushing the key fob. Now i am stumped. The other locks work perfect, key fob works ok.
Does any of the pins have a 12v supply that i can check, if i take out the mechanism is there anything i can do apart from throw it in the bin.
