Ford transit p2563 error code
Postby dctalbot » Fri Jun 05, 2020 4:22 pm
Hi
I have a ford transit sport 2010
Desperately need help, it keeps going into limp mode and showing a message on the dash (engine fault) it’s been to 2 garages and both come back saying they can’t find any issues. I got my own scanner that I used today, when it happened again a code come up P2563 turbo charger boost control position sensor a circuit range/performance.
Any help with this would be very much appreciated, I’m in the middle of converting this van to a camper and intend travelling to Portugal soon.
Dan
dctalbot
Re: Ford transit p2563 error code
Postby knobby1 » Fri Jun 05, 2020 10:14 pm
Which engine ps..? If it has an electronic turbo actuator it may be faulty or the wiring to it is not happy.
Postby dctalbot » Sat Jun 06, 2020 12:49 pm
Hi thank you for your response
It’s the transit 140 t260s stp fwd 2198cc 140bhp
I hope this helps
dctalbot
Postby knobby1 » Sat Jun 06, 2020 9:45 pm
dctalbot wrote:Hi thank you for your response
I hope this helps
The 140 has an electronic turbo actuator, they are are known to be troublesome sometimes...also check the wiring/connector to it.
Postby dctalbot » Sun Jun 07, 2020 10:10 am
Thanks very much I will look into both
dctalbot
Postby dctalbot » Sun Jun 07, 2020 10:29 am
Is it normal for the engine to make a wooshing noise under excelleration ? Is this just a normal turbo noise or possible leak ?
dctalbot
Postby knobby1 » Mon Jun 08, 2020 12:37 am
dctalbot wrote:Is it normal for the engine to make a wooshing noise under excelleration ? Is this just a normal turbo noise or possible leak ?
Ah...you may have a boost leak...check the boost hoses, inlet manifold and intercooler for splits/leaks.
