Hi There,
New to the forum as I have just purchased as 2011 Mk7 Transit SWB 85. The van did not come with the remote locking Blue key just the plain black one with the blue chip, I have now purchased a new Blue key from Ebay with the internals etc and had this cut and programmed by a local specialist in Bristol and the key will unlock the the doors manually and start the vehicle but will not unlock/lock the doors using the remote aspect. We tried another blue key from a friends van which we reprogrammed with all the correct equipment but still will not unlock/lock the doors. the key is transmitting as the electrician can see this on his Autel machine. Can anyone please shed some light to what this fault might be and why the key will not work the remote locking. The central locking works fine when you insert the key into the lock on the drivers door and work it manually. Thanks in advance.
