Loss of power ?
Loss of power ?
Postby reallyoldian » Fri Aug 14, 2020 9:44 am
I hope someone can help advise as my mechanic cannot :?: I have a mk7 2.4 tdci which normally runs like a dream. no smoke starts great etc ,lately its been losing power after about 20 miles its like there is no turbo most noticeable going up hills ,turn it off then start it runs great for 20 ish miles then same again , changed fuel filter and air filter ( wishful thinking ) no difference ,Mechanic put it on his computer thingy no codes ! ,Any advice would be greately appreciated or if anyone knows a good transit mechanic near Durham ! :D
reallyoldian
Re: Loss of power ?
Postby knobby1 » Fri Aug 14, 2020 10:15 pm
Any DTC lights on the dash..?? Do you know what code reader was used..?? Some readers struggle with the Transit protocols.
I'm guessing the EGR valve is not happy.
Re: Loss of power ?
Postby amlav » Sat Aug 15, 2020 10:59 am
It could be also the venting hole on the fuel filler cap blocked and creates a vacum in the fuel tank .
amlav
Re: Loss of power ?
Postby Stumble » Sat Aug 15, 2020 11:06 am
Might be worth cleaning the map and maf sensors -maybe the egr needs doing too
Stumble
Re: Loss of power ?
Postby reallyoldian » Sat Aug 15, 2020 1:00 pm
Hi ,thanks for the replys , No lights on the dash there was a spanner one a couple of weeks ago which i cleared ,just got back from a 30 mile drive did not misbehave at all
I will get the egr looked at , are the ones you get off ebay any good ?
reallyoldian
Re: Loss of power ?
Postby knobby1 » Sat Aug 15, 2020 10:04 pm
reallyoldian wrote:Hi ,thanks for the replys , No lights on the dash there was a spanner one a couple of weeks ago which i cleared ,just got back from a 30 mile drive did not misbehave at all
There's two types, go for this one..:
https://www.ebay.com.au/itm/EGR-Valve-f ... ect=mobile
There is also a water cooled and non-water cooled....check to see which you have before buying.
Re: Loss of power ?
Postby 2016Custom » Wed Aug 19, 2020 11:42 am
Could be getting air into the fuel line perhaps?
2016Custom
Re: Loss of power ?
Postby reallyoldian » Tue Sep 15, 2020 4:49 pm
Turned out to be a fuel valve ! Runs like a dream now
reallyoldian
Re: Loss of power ?
Postby knobby1 » Tue Sep 15, 2020 8:37 pm
reallyoldian wrote:Turned out to be a fuel valve ! Runs like a dream now
Fuel valve..?? Please explain.?
Re: Loss of power ?
Postby Stumble » Tue Sep 15, 2020 11:12 pm
SCV I bet
Stumble
Re: Loss of power ?
Postby reallyoldian » Thu Sep 24, 2020 5:03 pm
Hi Sorry for delay it was IMV valve .
reallyoldian
Re: Loss of power ?
Postby knobby1 » Thu Sep 24, 2020 11:14 pm
reallyoldian wrote:Hi Sorry for delay it was IMV valve .
So the SCV. Did you do a full set of learns after fitting the new valve..?
Re: Loss of power ?
Postby reallyoldian » Sat Sep 26, 2020 2:06 pm
Hi ,the garage did the lot , Van runs great they also removed the 70mph restrictor , only for France I would never speed here ! The only time that happens is when everyone is locked up or should I say down ? :D
reallyoldian
