TRANSIT MK7 2008 140PS CUTTING OUT
Re: TRANSIT MK7 2008 140PS CUTTING OUT
Postby Andrew 301 » Thu Aug 20, 2020 4:29 pm
Hi dont know if it is me but have tried to fit seals with some duck oil bout all i seam to be doing is teraring the seals as extremely tight when trying to push back in,any ideas?
regards
Andrew 301
Postby loot » Thu Aug 20, 2020 5:13 pm
Don't push them in just gently twist the injector return pipe with the seal on it and it'll plop in then. Don't push because it'll trap and cut them :(
Ids map here
loot
Postby Andrew 301 » Thu Aug 20, 2020 7:07 pm
Thank you
Andrew 301
Postby Andrew 301 » Mon Aug 24, 2020 4:37 pm
Hi still no luck fitting leak off seals,could it be that they are Ebay non genuine ones?
regards
Andrew 301
Postby Stumble » Mon Aug 24, 2020 4:48 pm
Andrew 301 wrote:Hi still no luck fitting leak off seals,could it be that they are Ebay non genuine ones?
regards
I'd say yes to that, but mine were ebay and were fine
Not on their own thoughhttps://www.ebay.co.uk/itm/FORD-TRANSIT ... 2749.l2649
Stumble
Postby Andrew 301 » Tue Oct 13, 2020 1:27 pm
Hi Thanks for all replys on previous post,i now have another problem on a different Transit a 2009 MK7 2.4 115ps which will not fire unless on easystart,i have put both left diesel pipes into a new container of diesel also a new pcv,i have also changed the diesel pump and still will not fire any help would be appreciated?
Andrew 301
Postby Stumble » Tue Oct 13, 2020 2:32 pm
I believe the more common causes of non start ( assuming its turning over ) are
Ignition switch
SCV
EGR stuck shut ?
Stumble
Postby andz327 » Tue Oct 13, 2020 6:23 pm
What happened with the previous van? Now another non runner and just throwing parts at it isn't the way to go
ANDZ
andz327
Postby Andrew 301 » Tue Oct 13, 2020 7:44 pm
Hi previous van swapped tank gauge and pipes to tank and seems ok now
rgds
Andrew 301
Postby V184 » Wed Oct 14, 2020 5:14 pm
Check the engine loom hasnt rotted out
V184
Postby Andrew 301 » Wed Oct 14, 2020 7:16 pm
Thank you all for advice i will be checking tomorrow,just a quick one on the engine loom is there any particular place they are prone to rot?
regards
Andrew 301
Postby Andrew 301 » Sun Nov 15, 2020 1:41 pm
Hi checked loom and all ok,just a quicj one on the Egr valve once removed should it press easily in your hand with no electrical circuit connected?
regards
Andrew 301
Postby loot » Sun Nov 15, 2020 1:55 pm
It is spring loaded and its geared but no worm so it should push in but quite slow and hard until you feel the cogs move (like starting a bicycle in the hardest gear if that makes sense.)
I fitted a new 1 the other day. If yours just pushes away very easily then I'll say its goosed.
Ids map here
loot
Postby Andrew 301 » Sun Nov 15, 2020 1:59 pm
Hi thankyou Loot for quick response,mine is i say in the closed position as looks level and not depressed a tall but does not press in at all
regards
Andrew 301
Postby loot » Sun Nov 15, 2020 2:29 pm
F it doesn't press in that's fine and it wants to be closed, if it is off the vehicle and you can see it then you can blow on it to see if it easily leaks. I did with my new egr and it did but I pressed it on and let if come back fast and it sealed.
Anyway it should only open when it is connected and working, but if you press hard and slow it may open with the gears but should spring return. It should not just push in easily with no resistance.
Not really sure if we're on the same page here exactly mind :lol:
I'm referring to the valve itself.
Ids map here
loot
