smokin gun wrote:Hi Ned.
It was running quite rough the egr valve has not improved things ?
smokin gun wrote:The mechanic cleared all the codes.
The turbo air vacuum was seized.
Took the adjustable arm off and freed it off with release agent.
Running a lot better but still smoking.
The speedo is not working and the mechanic has found a speed sensor fault which effects the running.
The saga continues.
Next step is phone the scrappy what a piece of junk .
smokin gun wrote:Hi Guys.
Got the codes read.
The egr valve is stuck open.
speed sensor on abs (speedo failure ?)
My question is regarding the egr valve which i bought new (£130) can this be tested either in its position or when removed ?.
Apparently the supplier will only sell me another one for £130 and they will send the new (faulty one ?) away for analysis and they would issue a refund if they find it to be faulty.
Any inspiration out there !
smokin gun wrote:How long does the self cleaning operation take after shut down ? thank you in advance.
