davyjcb wrote:What colour is the rev band in the rpm counter? Has it got a green band between app1800 rpm and 4000 rpm or a red band from 4500 to 6000 rpm ?
Hi all clocks i have are red band only.
Been playing around someore now the origanal clocks are basically dead no comms no power.
tried 2008 clocks back in and they work.i reloaded the asbuilt file from ford but didnt help (ive now got a pto fitted to van if anyone has a spreed sheet so i can remove.
any ideas what ive done and can it be rectified. ive fitted some other clocks form a euro 5 2011 and configered as best i can from memory.
2nd problam .van has no side doors from factory and ive removed rear doors from the van and out of bcm but still cant lock the van. fitted mechansim back to harnes earthed pin 13,van locks,but remove the mechanism again and it goes back to unlocked after re opening. tried turning clf? on and chassi cab with no luck
Top
