knobby1 wrote:FritzZeus wrote:Hi
I wish to purchase just the fuse/fuse housing on the fuse board under drivers seat and wondering if anyone knows where I might get these other than Ford? Last time had to buy the whole board (used) to get the fuse cost me £35 on eBay?
Cheers
Stephen
Would really help if you told us what vehicle you have..?? But Ford may be your only option or a breakers.
it's a mk7 according to the post about putting a mk8 steering wheel in a mk7.
Do you mean the fuses that bolt down in the fusebox by the battery or batteries? They are often branded as Littelfuse, or called maxi or mega fuses, depending on which size you need. You can find them on eB@y, in Halfrauds, Eurine Cart Prats, or in your local car shop. Just take your old fuse with you and match it up.
Mat
