Best Diagnostics Tool / Software
Postby diego1255 » Wed Jan 13, 2021 1:37 pm
As the subject shows, I am looking for advice on the best, budget diagnostics suite.
Model: Ford Transit 2017 2 lLiter Diesel Eco.
Up to now, have been using Delphis DE150 with the 2015 version of the autocomm software. This worked fine until a newer 2017 model became part of the fleet. It appears the 2015 version of the software does not support a connection.
I am wondering what the current budget options are with maximum functionality. Preferred would be a wired method via USB and an OBD 2.0 connection, avoiding any android / bluetooth devices.
Is ELM327 a viable option?
Thanks for your help in advance, looking forward to hear back. 8)
diego1255
Re: Best Diagnostics Tool / Software
Postby dumper » Wed Jan 13, 2021 4:13 pm
Yes go for the Elm and Forscan that’s what is mostly advised on hear .
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby Jay2018 » Wed Jan 13, 2021 5:48 pm
As Dumper said, ELM: (this is the one I bought because this particular seller has sold almost 2000 units; has probably sold a lot more if you include other selling platforms)
https://www.ebay.co.uk/itm/Modified-ELM ... 2749.l2649
Download Forscan to your Windows laptop.
http://www.forscan.org
Get the free trial of the Extended license by following the information on the site.
2012 MK7 Transit Trend 125 T350 6 SPD FWD MWB MR (Frozen White) :D
2010 MK7 Transit Jumbo 100 - SOLD :(
Galant VR4 8th Gen Type S(TT), 300ZX(TT) + S14A(T), Supra MK3(T), Golf MK4 1.8(T), GS300 & Civic EG9 VTI (ALL SOLD)
Jay2018
Postby DaveXE » Thu Jan 14, 2021 11:02 am
I have previously always used launch or autel tools but recently have been using the Thinkdiag it can be bought on ebay amazon etc or if you are living in the UK you can check out https://thinkdiag.co.uk . This is made by launch and uses the same software but it is much cheaper than buying a launch device. It has enhanced code reading actuation tests and special functions to a near OE level and is a really good piece of kit, If you want me to check if anything in particular is supported for you let me know but this is a good piece of kit.
DaveXE
Postby knobby1 » Fri Jan 15, 2021 10:55 am
DaveXE wrote:I have previously always used launch or autel tools but recently have been using the Thinkdiag it can be bought on ebay amazon etc or if you are living in the UK you can check out https://thinkdiag.co.uk . This is made by launch and uses the same software but it is much cheaper than buying a launch device. It has enhanced code reading actuation tests and special functions to a near OE level and is a really good piece of kit, If you want me to check if anything in particular is supported for you let me know but this is a good piece of kit.
We find the Bluetooth units tend to be a bit flakey and tend to drop out at the most inopportune times...not a good look when halfway through doing a set of learns or programming a pump.
Lord Knobrot etc..
Postby andz327 » Wed Jan 20, 2021 1:53 am
Was going to invest in launches Diagun........ with the thinkDiag is it make specific, does it cost more shekels per manufacturer?
Sent from my SM-G975F using Tapatalk
andz327
Postby DaveXE » Tue Jan 26, 2021 1:28 pm
The thinkdiag works on either one car manufacturer or all depending on the version that you buy and is made by Launch who are one of the leaders of diagnostic equipment. The thinkdiag is comparable to the launch pro tools and i have never had the bluetooth disconnect as described by another user above i have always found both launch and autel made tools to have very well built equipment. The thinkdiag supports special functions but also live data and actuation tests so it has no problem with sas reset dpf regen etc
DaveXE
Postby knobby1 » Tue Jan 26, 2021 9:11 pm
DaveXE wrote:The thinkdiag works on either one car manufacturer or all depending on the version that you buy and is made by Launch who are one of the leaders of diagnostic equipment. The thinkdiag is comparable to the launch pro tools and i have never had the bluetooth disconnect as described by another user above i have always found both launch and autel made tools to have very well built equipment. The thinkdiag supports special functions but also live data and actuation tests so it has no problem with sas reset dpf regen etc
Forscan does all this too, and more...and it's Free. The interface is less than 20 sheckles....a no brainer IMHO.
Postby davyjcb » Tue Jan 26, 2021 10:01 pm
I would agree with Knobby on this one, quite a lot of the major diagnostic tools are very good at what they do but the oem tool and Forscan take the functionality to the next level because they deal with 1 manufacturer only.
Most but not all others can read codes and run basic service functions /calibrations some can do more but you will pay a lot more for them, on purchase you might get 2 years of software package upgrades but after that how much???
96 escort 55 van gone
98 smiley mwb semi high gone
01 90/350 mwb semi high roof gone
05 135/350 lwb semi high roof gone
10 85/260 swb low roof leader gone
09 140/350 lwb semi high fwd
11 115/330 mwb semi high roof
davyjcb
cron
