Altransit wrote:As I said, it's probably being held in by carbon deposits, my No3 injector was the same. It needed a couple of hours turning side to side whilst applying upward pressure, and it eventually came out. Having another pair of hands helps
You need to be careful not to damage the injector too
Tiny Tim 610 wrote:As promised, here's the update.
The injector was refusing to come out, and we couldn't remove the rocker cover with an injector still in place, so we decided to sacrifice the rocker cover to get a better look. Once the rocker cover was out of the way, we were able to keep turning anti-clockwise until a 'threaded' injector came out in pieces. After a little head scratching (Lack of knowledge, but I do love a learning curve), we realized there was still more injector inside the cylinder head, so screwing the injector back together, spraying carb cleaner and gently persuading a clockwise turn, the whole injector came free.
Basically we weren't able to get enough clockwise turning with the rocker cover in place, and when turning anti-clockwise, the injector was just unscrewing but not loosening the carbon build up.
So, just waiting for the spare parts, and the putting back together can begin.
Thanks to those who shared there advice.
knobby1 wrote:Tiny Tim 610 wrote:As promised, here's the update.
Make sure all the old injectors go back in the same cylinders they came out of...and then when the "new" one is fitted, you need to "code it in" and then do the learns.
Tiny Tim 610 wrote:I'll be knocking on you door for advice
