2016 transit 2.0 EcoBlue B YMF6 crank no start P1212
Postby JJJ DA » Mon Feb 15, 2021 6:21 pm
hi everyone,
just get in the workshop a 2016 transit 2.0TDCI 2.0 EcoBlue B engine YMF61ABX.
crank no start. DTC P1212
fuel pressure while cranking 60bar. any ideas?
thanks
JJJ DA
Re: 2016 transit 2.0 EcoBlue B YMF6 crank no start P1212
Postby mindaugas » Tue Feb 14, 2023 9:54 am
Hey,
Any updates regarding this problem?
Looks like I have the same issue...
mindaugas
Postby The Woodfellow » Sun May 04, 2025 4:03 pm
Hi all,
I have a similar issue. 2018 Custom 2.0 Ecoblue. Over a year now! Engine died on the motorway. AA said cam chain (belt, obviously!) opened it up, belt intact, timed up etc. changed everything in there anyway, cleaned strainer etc. Checked with a friend’s entry level scanner. It had high pressure on the low pressure side and low pressure on the high. Changed the fuel filter (plus new oil and full service kit) no difference! Had a ford engineer around with his ford diagnostic. Injectors ok, but showing the same codes. P0092 p0088 and p1212:64-27. He recommended the fuel pressure regulator on the common rail. Fitted this and still the same codes. Gave up for a while, but every now and then had someone out to try to diagnose. Found and booked RAC mechanic for £99. He spent a long time going through each system and said that it was the control unit attached to the pump, this don’t come separately! But RAC said they could do the job. Took over a month to get their mechanic who turned up with a regulator I’d already changed and blacklisted me for arguing with him. I bought the special tools to change the high pressure injection pump for a new ford item (the timing gear fell off while i was removing the tool so had to set it by hand) So, I have a TopDon scanner (attaches to the phone but clumsy to use) it says the other codes are clear but p1212 remains. It felt like it wanted to start but chugged until the crank time warning came up. Now nothing so assumed a little fuel in the pump from factory test? Checked the low pressure pipe marked with red dash (assumed this was flow but didn't go into the bottle so?) fuel went all over the place. Is the red one the return? If so, it seem the fuel is going to the injector pump? I’m now thinking of changing the sensor and pipe 9J280 but seems that this was working. Unless it bypasses if faulty but have no idea how these work? I need help!
Kev
The Woodfellow
Postby mindaugas » Wed May 21, 2025 11:23 am
Hi. In my case 2017 2.0 Ecoblue didn't want to start after resting during the weekend. Code P1212 and rail pressure doesn't reach desired value (live data).
Fuel rail pressure regulator was suspected and changed before 30000km.
Managed to start with a help of easy start sprayer. It took 3-4 attempts.
It looks like my transit doesn't have low pressure fuel pump near the tank and fuel takes a couple of days to back flow. Therefore high pressure pump is not able to take it.
After discussion with local mechanic, we will try to instal one way fuel valve in the fuel line. Maybe it will help.
mindaugas
Postby metalworker0 » Wed May 21, 2025 12:42 pm
Fuel pump is in the tank ON THE CUSTOM
marked 9h307 on the diagram .
http://www.catcar.info/ford/?lang=en&l= ... EzMw%3D%3D
part number is marked 2086339 - but suspect it may be years out, as it says 2012 and the ecoblue was years later... but that is the diagram for the ecoblue.
Postby The Woodfellow » Sun Jun 08, 2025 2:30 pm
Minaugas.Did you get yours sorted? You will have an electric lift pump on a flow and return like mine. You prime just by turning the ignition till the lights come up. 3 x 30 seconds should be enough to prime from empty. I checked mine at the high pressure pump and had flow and return but not a lot from the high pressure pipe to the injectors.
The Woodfellow
