I currently own a mk7 2.2 2014 t350 tipper I’ve had a lot of parts replaced recently as I had a small wire burn out in the engine bay . I’ve changed the following :
Inlet manifold , rocker cover gasket , cam sensor I’ve had a new ecu also I’ve had all the timing checked . The truck starts up first time and sounds mint but it’s coming up ENGINE MALFUNCTION in the centre screen and is in limp mode . We cannot find out why we have checked everything we can think of that it might be I’ve had an auto electrician out to check all the wiring and he said it was all ok . I’ve spent nearly 2k up to now trying to get it fixed and I’m loosing hope please if anyone could help me or advise me on some ideas that would be gratefully appreciated
