Sat Nav SD cards
Sat Nav SD cards
Postby Pasty_PFC » Sat Apr 10, 2021 2:31 pm
I just bought a transit custom 2.2 290 TDCi 2014. It has sat nav but it isn’t working. There is a message saying it needs an SD card. Is there any recommendation on what to buy? I see on EBay there are cards ranging from £20 to £170.
Pasty_PFC
Re: Sat Nav SD cards
Postby workbox » Sat Apr 10, 2021 6:54 pm
32gb SD card would work sufficient.
also majority of devices have maximum capacity sd card that you can insert if you buy larger sd card e.g. 64gb/128gb your device might not accept/recognize.
workbox
Postby Altransit » Sat Apr 10, 2021 7:31 pm
Don't you need a specific SD card with the Ford satnav software loaded onto it :?: :?
Postby davyjcb » Sat Apr 10, 2021 8:02 pm
It's a pre-loaded sd card with the map info on it you need, most of the fleabay cards are old ones that have been replaced and probably 2 or more years old so you might be missing the odd bypass or a new road or 2
96 escort 55 van gone
98 smiley mwb semi high gone
01 90/350 mwb semi high roof gone
05 135/350 lwb semi high roof gone
10 85/260 swb low roof leader gone
09 140/350 lwb semi high fwd
11 115/330 mwb semi high roof
davyjcb
Postby Pasty_PFC » Sat Apr 10, 2021 8:49 pm
Thanks guys. For £20 I’ll give it a go.
Pasty_PFC
Postby Pasty_PFC » Sat May 01, 2021 8:00 pm
Bought one for £16.99 on EBay. Works perfectly!
Pasty_PFC
Users browsing this forum: BimmerGuy
