Mk5 Central locking
Mk5 Central locking
Postby Mac1984 » Sun Apr 11, 2021 11:35 am
Hi all, only out of interest :
My mk5 has central locking, everything works as it should, it came with a broken remote when I got it, I tried to fix the remote
And it has worked briefly, but the fob then broke again, the plate inside was very damaged.
How straightforward is it to replace the thing with a new one?
I was thinking of somethin like this:
https://www.ebay.co.uk/itm/REMOTE-KEYLE ... 0315645521
It said in the discription something about only for cars with key lock, so this is an upgrade for cars that had key, but no remote lock. But does it matter?I mean you would change the unit anyway suppose?
And where is the receiver unit located in the mk5?
Thanks for all your suggestions.
This might be a project in the summer maybe.
1996 2.5TD Bosch Mod, Bio degradable Body from factory but outlived its manufacturing plant.
Mac1984
Re: Mk5 Central locking
Postby Altransit » Sun Apr 11, 2021 1:39 pm
I didn't realise that they had RCL on the Mk5, mine only worked with the key in any lock, and the only door without a lock was the SLD :?
Postby Mac1984 » Sun Apr 11, 2021 1:50 pm
It may have been an aftermarket idea of the previous owner, I don't know.
Unfortunately I don't have the fob anymore, but it was nothing ford-like, just a little round plastic thingy with two buttons.
Mac1984
Postby Altransit » Sun Apr 11, 2021 2:04 pm
Was it an alarm fob, like this?
You could use the Cobra alarm fob to "remotify" the central locking, my son did it on his Escort which only had key central locking. It could probably be done with other makes of alarm too :)
Postby Mac1984 » Sun Apr 11, 2021 6:52 pm
Good Thinking.
The Fob looked very similar to what you are showing there.
Maybe the best way would be to find the receiver of the old fob and see what it says on it?
PS: good name for the alarm too, Cobra :-)
Crime is a disease, i am the cure :-) :-)
Mac1984
Postby MinorMatt » Mon Apr 12, 2021 8:55 am
Remote central locking was not available on mk5 - so what you have is definately and aftermarket set up.
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Postby Mac1984 » Mon Apr 12, 2021 12:38 pm
Thanks Minor Matt.. So this is confirmed now. Which also means that the receiver unit could be installed anywhere.
Any thoughts regarding what I have posted on top? Seemed much better value then the cobra thingy.. I don't mind really what it is..
So if I find the old unit and replace it, that should work? I don't care about flashing indicators or keyless entry for example..if that function is there as well and works, fine, but I don't really need anything apart from lock/unlock function.
This is not an urgent thing either, so I keep looking for whatever seems reasonable
Thanks for all your thoughts..
Mac1984
Postby MinorMatt » Mon Apr 12, 2021 1:02 pm
There is a good chance that the reciever is inside one of the doors - it won't be the side loading door because that doesn't have the electrics to "control". My best would it being inside the drivers door...
As for the aftermarket ones, I guess they probably work just fine - but I have no direct experience
93 L GL Minibus
Postby Mac1984 » Mon Apr 12, 2021 1:20 pm
Thank you for your thoughts.
I had the driver door apart some while ago to replace the window motor..
Definitely not in there, but I give the other door a try at some stage. .
Thanks a lot, I'm sure it can't be far..
Mac1984
Postby MinorMatt » Mon Apr 12, 2021 1:57 pm
Possibly behind one of the fake speaker grills in the footwells then
93 L GL Minibus
Postby Mac1984 » Sat Apr 17, 2021 12:07 pm
Spot on Minor Matt
I found the Unit behind the passenger side footwell lining.
Well done.
Thanks for your help
Mac1984
