Connect 06 reg. 106,000 miles.
Postby redhillphil » Fri Apr 16, 2021 8:18 pm
Hello all. I'm new here and I do hope that this is in the correct place and if not someone could take me gently by the ear and lead me to the correct place.
My Connect is making noises that means that it's not a happy connect.
Noise number one.
From the front nearside wheel a steady squealing - not very high pitched - a sort of light resonant metal against metal sound. I thought that it might be brake related so I've had the wheel off, taken the pads out, brushed all around, re-coppered the pads and put it all back to-gether again. Still squealing. Rolling along in neutral with the engine stopped makes no difference. Brakes applied or released makes no difference. Not a low pitched grumbling bearing noise.
Noise number two.
Lots of heavy duty clunking/clonking noises hitting bumps and holes on the road from the front offside. Ball joints, drop links? Miscellaneous suspension problems.
I'm not familiar with the van. Since 1981 I've only ever owned Saabs.
Thankyou in advance.
Phil.
redhillphil
Re: Connect 06 reg. 106,000 miles.
Postby karl » Mon Jun 14, 2021 10:37 pm
maybe wheel bearing
these are a cassette bearing and can make the noise you on about also dont show signs of play either
stip down and turn by hand to feel for rough spots
done mine recently as i had a droning noise on acceleration and de acceleration
karl
Tranny Lover!!!
Postby gotgcoalman » Tue Jun 15, 2021 12:15 am
Clunky clonk is possibly bottom ball joint
Sent from my Plus E using Tapatalk
Too bloody quiet :shock:
gotgcoalman
