Mk5 reversing light
Mk5 reversing light
Postby npjrogers » Fri Apr 23, 2021 9:29 am
My ‘96 mk5 smiley banana motorhome is away getting a MAJOR bodywork rebuild. (4k’s worth) When we get her back she is getting a new radio that incorporates a reversing camera. Where is the best place to pick up a control signal for the camera bearing in mind it will be wired to the back of the radio? The camera video signal has 18ft of lead hopefully enough for a swb.. I will post some before and after pics when the job is finished.
Sic Transit Gloria
npjrogers
Re: Mk5 reversing light
Postby MinorMatt » Fri Apr 23, 2021 11:45 am
The wiring to the rear lights go up the windscreen pillars... I would pick up the feed for the head unit there, and the camera at the rear lights
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Postby Noctule » Fri Apr 23, 2021 6:39 pm
on the headunit in my mk7 the signal wire that switches it to reversing camera is built in to the video cable, the 12v from the reversing light that powers on the camera then becomes the signal to the headunit too. your cable might be the same, and it saves hunting for a wire in the loom.
Mat
2000 Mk5 HiCube self-build camper
- 2.5tdi 4EA with EPIC-to-Bosch conversion
- DRW with 16" rims
- Mondeo instrument cluster
- Lunar Meteorite interior
2006 Mk7 115t350 van (cheap tax tramp)
Previously...
Mk5 100 swb Custom
Mk5 190 lwb x3
Noctule
Postby npjrogers » Sat Apr 24, 2021 11:06 pm
Brilliant.. here is a link to the Amazon product I bought.
https://youtu.be/gBI-Av5N-Ic
Dont be fooled by the title.. £60 in UK
Sic Transit Gloria
npjrogers
Postby npjrogers » Sat Apr 24, 2021 11:07 pm
Sic Transit Gloria
npjrogers
Postby Noctule » Sat Apr 24, 2021 11:44 pm
that's a nice bit of kit for the dosh. I've found a remote control rather handy in a motorhome (my seating is at the rear).
Should be easy to fit. Don't cut your cables if possible, buy an adaptor cable to go between the stereo and your loom and modify that instead. Makes it easy to refit your original stereo.
- DRW with 16" rims
Previously...
Mk5 100 swb Custom
Mk5 190 lwb x3
Noctule
Postby npjrogers » Wed May 26, 2021 6:26 pm
Thanks everyone.The reversing camera is now installed. I began by locating the correct wire on the offside rear light cluster. Use the feed wire to the reversing light and check that it is showing voltage when the reversing light is on. On my van it is the Violet and orange wire.. not as shown in the Haynes manual… I decided not to drill any holes in the bodywork. I mounted the camera inside the top of the rear door by sliding it into the mounting rubber of the rear door window. It faces down nicely. I ran the cable behind the sink and cooker up at the level of the join between van roof and grp hightop. Worked a treat. Under the driver side ceiling trim and down through the right hand A post. From then on it was easy. Connect the red signal cable to the pink trigger wire on the back of the head unit. All working well.. thanks all.
Sic Transit Gloria
npjrogers
