Mk6 Ford transit not turning over
Postby andy_uk127 » Sat May 08, 2021 4:03 pm
I have a mk6 transit recovery truck and it cut out while driving I have read some bits on here and I think it may be the cable that runs from the pcm to the ecu that powers the key reader and other bits I have had a look and found the cable that I have put picture up of can anyone tell me where this goes to and also where I can locate the wire from ecu to pcm thanks in advance
andy_uk127
Re: Mk6 Ford transit not turning over
Postby knobby1 » Sun May 09, 2021 8:28 pm
The connector in your pic looks like the "water in fuel" sensor wire...lives on the bottom of the fuel filter.
Have you had the codes read..?? Glow plug light flashing..??
