1998 camper. Sometimes OK uphill, sometimes struggles
Postby mrwilko » Tue May 11, 2021 4:37 pm
Hello,
Newbie here, hoping for some help. I have a much loved 1998 Transit based 'Duetto' Smiley (not banana engine). Last year I noticed a problem climbing hills worse than the normal leisurely ascent caused by camper weight. I had a service including having all the filters changed. That temporarily solved the problem. When it mysteriously re-appeared I had the turbo replaced. The first long journey with the new turbo the same problem happened again but then mysteriously disappeared. Last week it happened then improved after an oil top up. On a long journey this week It was fine one day and bad the next. Any ideas gratefully received and happy to answer further questions.
mrwilko
Re: 1998 camper. Sometimes OK uphill, sometimes struggles
Postby MinorMatt » Wed May 12, 2021 7:22 pm
What does the engine management lamp do?
Auto or manual?
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Postby mrwilko » Wed May 12, 2021 7:35 pm
Manual.
Engine management lamp? Sorry I need you to explain that. Thanks for the reply.
mrwilko
Postby MinorMatt » Thu May 13, 2021 8:18 am
As a turbo it should have an engine management lamp - a light that comes on on the instrument cluster when you turn the ignition on.
Its red and has a picture of an engine.
It should come on when the key is turned on, and turn off when the engine is running
93 L GL Minibus
Postby mrwilko » Thu May 13, 2021 9:59 am
Hi. Sorry, didn't know about that, never seen it. Will start up and have a look.
mrwilko
Postby mrwilko » Thu May 13, 2021 12:01 pm
Hi again,
No red lights continued on after start up. Thanks.
mrwilko
Postby Chug » Thu May 13, 2021 1:44 pm
Does the light come on when you turn the ign on? or have you no light at all?
Chug
Postby mrwilko » Thu May 13, 2021 8:15 pm
No light. I think it's too old to have one. I've got batt, oil and brake but no engine symbol.
mrwilko
Postby MinorMatt » Sat May 15, 2021 2:37 pm
well the management light is present on all transit turbo diesels since 1992 - so it sounds like someone has removed it to mask a fault.
You need to get it plugged in by someone with the correct equipment (Lucas Laser 2000)
Where are you?
93 L GL Minibus
Postby mrwilko » Mon May 17, 2021 2:00 pm
I'm in Bournemouth but frequently travelling around the south for work. Where on the instrument panel should the light be?
mrwilko
Postby Chug » Mon May 17, 2021 11:18 pm
between the fuel and temp gauges
Chug
Postby mrwilko » Tue May 18, 2021 10:07 am
OK thanks, I'll have a look at that.
Let's say there is a fault that the lamp removal is masking, based on the symptoms described previously in the thread, any ideas what it might be?
mrwilko
Postby MinorMatt » Tue May 18, 2021 10:12 am
Sticky cam plate in the injection pump (adding 500ml-1L of mineral 2 stroke oil to each tank of diesel may help - if not new injection pump needed)
Faulty cam position sensor
Faulty rotor position sensor
Fuel filter issue
Lift pump issue
Partly Binding brakes
Overboost
Underboost
boost leak
If you are around Newbury at any point I could plug it in for you with the correct diagnostics. (outside office hours)
93 L GL Minibus
