by trev9712 » Thu May 20, 2021 8:41 am
My heater fan only works on 3 & 4 which suggests the fan resistor. I have removed the glovebox and can remove the plug from the resistor, which only makes it run on number 4. I can see the screw which holds the bracket down, but unless your arms are the size of a pipe cleaner, how are you supposed to unscrew it? Also, on another subject, the single rear door has started to rattle a lot and I cannot see how to adjust it. Any clues please?
