Waterless Coolant, Scam?.
Postby andypdq » Thu Jun 17, 2021 8:11 pm
Not been on here for an awfully long time, so hello again.
Does anyone have any experience of using waterless coolant? Waterless coolant is propylene glycol as far as I know. It has a much higher boiling point than water, but it's specific heat capacity is far lower than water, which means that it is less efficient at transporting waste heat from your engine to your radiator, which means that your engine will potentially run considerably hotter than it's design temp when running waterless coolant, but it won't boil. I'm somewhat nervous about using waterless coolant.
The first Mk 6 mechanical TDDI, giving electronics the finger, since April 2013
Perfection is reached, not when there's nothing left to add, but when there's nothing left to remove.
YouTube https://www.youtube.com/channel/UCNypVH ... dKUN5eJDyQ
andypdq
Re: Waterless Coolant, Scam?.
Postby Mike » Thu Jun 17, 2021 8:40 pm
It’s a bloody waste of time in most vehicles imo, it’s benefit is lack of pressure buildup, but I don’t see that as a benefit in a Transit. Some classic car owners swear by it, but I don’t know anyone who’s used it long term, they usually go back to water and antifreeze. The only worthwhile cooling additive I’ve used is water wetter which will reduce temperatures slightly.
Mike
Wind up merchant!
Postby andypdq » Thu Jun 17, 2021 9:07 pm
It's heat capacity is less than conventional coolant, your water pump moves the same volume of coolant per minute so it's able to transport less heat from your engine to the radiator than conventional coolants, so your cooling capacity is actually reduced, it won't boil but your engine will still overheat, that's great!
andypdq
Postby Mike » Thu Jun 17, 2021 9:09 pm
You obviously realise that it’s not for Transits as you’ve posted the same thing twice.
Mike
Wind up merchant!
Postby Airthies » Thu Jun 17, 2021 9:14 pm
I've had "ELC" (CAT Extended life coolant) in my vans for a few years now, can't comment as such but might try a change as had a couple of times it's got hotter under heavy load hard acceleration.
Sent from my A55ho11 using Crapatalk
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby andypdq » Thu Jun 17, 2021 9:28 pm
Mike wrote:You obviously realise that it’s not for Transits as you’ve posted the same thing twice.
Maybe alerting people to the facts could be a beneficial thing ?
andypdq
