Hi All, have just come across this forum so will be here to stay now
I’ve just replaced a broken cambelt on 3 year old custom eco blue.
It snapped at very low speed so hoping damage was to a minimum?
I’ve drained and stripped everything down and cleaned the sump etc
Locked the 2 camshafts in place and aligned the timing marks up on the crank and the middle shaft as per all the manuals etc i noticed there was a timing mark on the fuel pump pulley and the crank but couldn’t get these to line up??
I’ve since replaced all the belts, new cover new oil etc and rebuilt her up.
Bit ropey at first to start put that down to changing the fuel filter, she then fired up but is running on 3, could this be a timing issue with the fuel pump or could it be one of the lobes on the shafts twisted ?
Any help would be greatly appreciated, this is my first one and I’m hoping the last! I have 5 more of these bloody vans
Cheers
Dave
