Hi all, 1st post, so I hope it's in the correct place.
My local charity (Air Cadets) has a Transit minibus 2009, it came fitted with a tacho (VDO 1381 v1.3 12 volt, which they are exempt from using under their insurance.
Due to Covid, the bus sat for a few months, the battery went dead and the tacho now doesn't work which I'm told is common as the internal tacho battery was never replaced.
The mileage now doesn't display on the dash or the tacho, which is needed for MOT, insurance and the logs the charity has to keep.
A local company quoted £875 to replace it and calibrate it.
Ford said they can't remove them if they have been fitted, legal issue?
All they need is the miles to be displayed, so my question is 3fold.
Can I bypass the and get the miles back on the dash without some sort of OBD / CanBus cable. I.e unplug and plug in somewhere else.
Can I buy a used of eBay or similar for £150 and just install it without calibration, would that display the correct mileage
Is there any companies you can recommend that wont want £875, the charity can't afford it and they can't use the bus to take the children to events etc.
Is there any form of digital display available that would plug in and display the mileage?
Hope you can help.
Many thanks
Phil
