Hello. I have read several threads but don't seem to find the same problem.
I have a Campervan built on a 2006 Ford Transit MK6 2,4 TDCI. 52000km (fuel filter changed 1 year ago, Mann WK8154)
The fuel line seems to be blocked and the 2 indicators (1 on filter housing and 1 on feeding line to fuel pump) goes straight to red and can not be reset, som it seems that there is a stop causing vacuum in the diesel line.
Short story: Have owned it for 5 years, last year on a trip we got very low on diesel and stopped in a little hill. would not start, ran and fetched some diesel and it started. had do to let air out of filter a few times. After that I believed it was because of low diesel. But now it has happened again.
After running 250km we made a sop for about 30 min. I started it and drove 2-3 km and then it stopped. Stop I fuel line. Released fuel filter, filled it up with new diesel and it started, Drove 2 km, let it idle. everything fine I thought. stopped the engine but when I started it it stopped again. indicators on red. had 2 do the operation a couple of times before it would idle steady. Drove 300km, everything fine. Drove 400km yesterday with atleast 4 stops, worked perfectly. When I got home yesterday I stopped the engine and after 5-10 minutes started it to park it properly, came 20meters and it stopped, the indicators was on red and could not be reset. Waited 10-15 minutes and then I was able to reset indicators and start engine. it started on 1st turn. had It idling for a longer time, no air in diesel, just idling fine.
Seems something is blocking the fuel feeding line to filter. Only has happened with warm engine, warm diesel.
Any thoughts please.
